1990 Toyota Camry Stereo Wiring
Username: Carfix005
I have a 1990 Toyota Camry DX(Deluxe) and I took the factory stock
stereo out and bought a Pioneer DEH-P2900MP version stereo a couple days
ago and was wondering how in heck you would go about making it work, I
mean I have got a diagram and everything for it and it tells me what
wires on the Pioneer connect to which wires on the Camry, I connected the
black(gound wire) to the brown wire, the Red(ACC/12V+ switched wire) to
the gray wire, and the Yellow wire(12V+ constant) to the yellow/blue
wire on the car but nothing happens, the radio will not power on, I can't
figure what would be wrong.
This is the diagram I got form the internet....
The wiring for your car is as follows and wire in parenthesis is
pioneer wire.
Constant 12V+ Blue/Yellow (yellow)
Switched 12V+ Gray (Red)
Ground Brown (black)
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Driver's Pillar
Front Speakers 3 1/2" Dash
Left Front (+) Pink (white)
Left Front (-) Purple (White w black tracer)
Right Front (+) Light Green (Gray)
Right Front (-) Blue (Gray with black tracer)
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black (green)
Left Rear (-) Yellow (Green with black tracer)
Right Rear (+) Red (Purple)
Right Rear (-) White (Purple w black tracer)
But that doesn't seem to work, As I said I connected all the power wires(not the speaker wires yet
though) to see if the Unit would power on, but it does not...Am I doing
something wrong?
Thank you for any help or information you can provide me, It is
greatly appreciated.
Username: Illuminator
Post Number: 4970
Have you checked the fuse?
One way to get this figured out is to disconnect everything except for the power wires and see if it powers up. If it does, add on each wire at a time and see if any cause it to not turn on.
Username: Carfix005
Where would the fuse be located at?
Post Number: 5003
In the main fuse panel, the owner's manual should have a diagram explaining where it is near the back of the manual.
