Pansat 3500 install help
Username: Sp1985
im a total new comer to FTA. i dont even know how the thing works.
i just got my pansat , i loaded the boot b80 file the new bin,
but no i cant figure out how to get channels.
i want to get indian channels , which are on i believe but could be wrong echo 7 , which is 119west. i cant even tell if im getting a signal from the sat. cause the level says 70%, but the quality is 0% .
so what do i do?
Username: Rtap
MIAMI, FL MIAMI
Post Number: 84
first make sure your dish is pointing the correct way.since you a newbie have someone align the satellite for you. then do a satellite scan
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 169
(1) look around the area for others and point ur dish in there general direction.ur not the only one doing this in ur area. the bev dish gives it away all the time.
(2) on the 3500 remote press the green button twice.
there is a signal meter make sure u turn ur volume down. u can here it outside. it is loud.
once u find the sat u want lock dish down.
u can do this with the switch at this time or without. i do it with. but make sure u turn power off on reciever and unplug it before u connect or dis-connect any sats. u will burn ur switch.
i set all my switch settings first then disable the ones i'm not blind scanning so i do get double channles
"it's really ur prefirance the way u want to do it"
or go to
http://www.l@ngsat.com/tracker/america.html
change @ to y
i dont know where ur located so go here for headings.
plus i dont know what type of dish,lnb settings u have.
so assuming that you have a basic setup i will try to help.
(3)find the latest bin here bin 312
http://www*future-fta.info/Forums/showthread.php?p=333664#post333664
make sure u back up the bin in ur reciever first.
to do this u hit menu on the remote
then hit sd memory.
then hit the file codebackup.
press the red button on the remote hit yes,
name the backup then let it backup.
(4) after that
put ur sd card that into a reader and copy the latest bin to the code backup file.
then go back to ur reciever and press menu on the remote.
then hit sd memory
then code backup.
instaed of the one u backed up highlite the latest bin.
instead of hitting the red button this time hit ok.
confirm that u want to restore data hit ok then let bin load.
reciever will take a few minutes just be patient.
(5)after reciever reboots
go the menu
then parentel control
then second pin
enter 0000
scrow down to set default key. " this is after u have ur sats tweaked in " then exit
scan the birds u want.
make sure u set ur DISEqC switch in the reciever to the proper bird u want. 119, 110, 82
i dont know what ur setup is but this is the average way to do a 3500.
u can also load a channle list once u get the birds u want
thats just a quick way. if u need more detial let me know......
may be a little out of order but it's early and i'm st0ned.
good luck......
look around for lk he will help ya' out also
first he will tell u to read till ur eyes bleed.
but he'll help out also.
right LK ? LOL
he helped me out back in the day when i first started
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 170
i geuss he got it going.
aaahhhhhhh..........ur welcome
