Two Kenwood 12"
Username: Guismo
Truro, MA US
I have Two Kenwood 12" not sure model # I just know they are 1000watt ea. My amp is a Rockford 301m punch 900watt mono. Can I hook them both up to the amp in any way?
Username: Jaackdeth
United States
Post Number: 738
Is that rms or peak on those subs?
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1793
Well the output of the amp isn't as important at the moment as the VC configuration of the subs. I.e. SVC, DVC, SVC 2,4 ohm, DVC 2,4 ohm?
Username: Guismo
Truro, MA US
Jack, That would be 1000w peak and I believe 600w rms
Username: Ruler1153
Youngstown, Ohio United states
fellas I have unmatched pairs of subs for my Cadillac Deville okay. 2-dvc 2Ohm 2-svc 2ohm okay. The problem I am having is that when i run them as unmatched pairs My Kenwood 9152d goes into protection. the power ratings are compatibale but what causes the amp to protect? Need wiring ideas. thanks in advance fellas...Ruer 1153...Tupac Lives
