BEV to DN
Username: Lt5000
Switched from BEV to DN last weekend just to check out DN. Scanned Sat 119 and had limited channels, only HBO latino. I would like to get HBO and Showtime as well as the ESPN's
Any suggestions out there, did I need to scan more Echo's or AMC's
LT5000
Username: Cntrlaltdel
Post Number: 128
It shoulda' brought in all the HBO's and ESPN's... sure you didn't scan 110?
Username: Lt5000
Not really sure. The sat said Echostar 7 and that's what I used to pull in the signal.
Just slightly Right and angled down from BEV.
When I get the signal again, what sats should I scan.
LT5000
Username: Northman
Post Number: 178
The receiver can display any name it wants to. Mark the post & dish with a reference mark & move the dish a bit more to the west & a couple more degrees down & when you get the next strong signal, that will be 119. ( make sure to check with Lyngsat & transponder frequencies & polarities for the channels you want to get & set your machine first, before moving the dish ).
Username: Joed
Post Number: 21
HBO lat is on 110. You need to go more to the west to get 119.
