ARE 10 inch solobaric L7's good off an A800t audiobhaun amp?
Username: Ceoofdaroc4
hey im thinking about getting two 10inch kicker solobaric L7's the peak wattage is 1200 and i think they run constant at 900 watts... if i get two audiobhaun A800T"s (which are 800 watt) for each sub bcuz i already have one of these amps will i get major bass without blowing the sub or ruining my amp?
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 400
ulll get alot of bass but most people say that the l7 lacks the sound quality but if u wanna get loud loud get em and yea that combination will work
should i get a ported or sealed box which one is louder and which one has better sound quality i have a little car its a 97 mazda millenia
TWO EGG, FL USA
Post Number: 402
dont get the l7 is u want sound quality they just get loud and ported is always louder
Username: Oleg
Santa Monica, CA USA
Post Number: 484
You won't get much SQ from them anyway, so go ported if you want loud.
well what should i get for very loud bass and good sound qaulity too thats comparible to these and their price?
Username: Nd4spd18
Southeast PA
Post Number: 664
whats your budget?
