Bronze Member Username: TurnmatPost Number: 15 Registered: Feb-07 | i am looking to hook up a secondary alternator for my system and keep the stock alternator for the car accessories. does anyone have any diagrams on how to do this? thanks, matt |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3684 Registered: Jan-06 | what kind of car do you have. you will need custom made brackets. |
Bronze Member Username: TurnmatPost Number: 16 Registered: Feb-07 | 2003 dodge intrepid 3.5 liter |
Silver Member Username: Nd4spd18Southeast PA Post Number: 797 Registered: Jul-06 | " you will need custom made brackets " Yep. Get ready to fork over a ton of cash for that. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3693 Registered: Jan-06 | look and see if there is even room in your engine bay to add the alt so its in line with the other belt, otherwise you cant even do it really |
Bronze Member Username: TurnmatPost Number: 17 Registered: Feb-07 | not enough room |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1874 Registered: Dec-06 | 8 300 amp alts FTW!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Bronze Member Username: TurnmatPost Number: 29 Registered: Feb-07 | what kind of vehicle and where do you have them located? |
Gold Member Username: B101Everyone is ... USA Post Number: 4212 Registered: Sep-05 | www.excessiveamperage.com |
