JVC - got replace lamp message
Username: Kellyjef
NIAGARA FALLS, NY United States
I got the replace lamp message when I turned on the tv this morning.
When the bulb burned out last year, it simply "popped" and the screen went black. This time I got the replace lamp message.
Do I need to replace the lamp immediately (I did buy a spare so I have one)?
The picture is perfect -- can I wait a while before putting in the new bulb? Will the picture just start to get worse and worse?
I don't want to do anything to damage the tv.
Username: Tvshopper
Post Number: 97
Kelly,
That message is triggered by an hour counter, nothing else. I think it's possible that somehow it didn't get reset when you replaced your bulb last year because I wouldn't think that the warning would be displayed before 5,000 hours or so. It is hard to believe that you would rack up that many hours in a year.
Anyway, you're not going to do any damage to the TV. Continue using it until the lamp goes.
Username: Kellyjef
Thanks!
Actually, my husband is disabled so he's usually home with the tv on for as many as 18 hours a day so the tv does rack up a lot of hours :-(
We bought the tv on 2/20/05.
The bulb was replaced free on 1/18/06.
Username: Tvshopper
Post Number: 98
Kelly,
You're welcome. So, it is probable that your lamp has 5,000+ hours on it? That's encouraging from a lamp-life perspective.
Username: Potentialjvcowner
Post Number: 48
The key may be that it may only be turned on/off once per day. There has been some suspicion that you could get dramatically more hours with such a use pattern.
Username: Tvshopper
Post Number: 114
Barry,
The number of on/off cycles definitely affect lamp life. In fact, if I know I'm going to step away from my TV for three hours or less, I leave it on rather than cycling it.
