New member Username: Court2101
Bartlesville,
Oklahoma
United States
Post Number: 7 Registered: Apr-06
Posted on IM WANTING TO REPLACE MY FACTORY SPEAKER IN MY DURANGO BUT IM NOT SURE WHICH ONES I SHOULD GET IM CHOSING BETWEEN INFINITY REFERENCE 6012SI KICKER 05DS60 Pioneer TS-G1641R Blaupunkt GTx652 JBL Power P652s Alpine SPS-17C2 ANYONE HAVE ANY IDEADS ON SOUND QUALITY ON ANY OF THESE??? |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 575 Registered: Jul-06
Posted on TURN OFF THE CAPS LOCK The Alpine and JBL should be ok but none of those are real great. You may want to consider one of these brands: Adire Audio Alpine (F1 Status components) Arc Audio Beyma Boston Acoustics Bravox (component sets) CD Technologies (CDT) Diamond Audio DLS Dyn Audio Eclipse Focal HI-VI Research Illusion Audio Image Dynamics Infinity (Kappa Perfect series) JL Audio (XR components) JL ZR component line LPG Max-Fidelity MB Quart Morel Rainbow Resonant Engineering Scan-Speak Seas Vifa Visatron |
Bartlesville,
Oklahoma
United States
Post Number: 9 Registered: Apr-06
Posted on sorry bout the caps im at work and we have to use caps on everything thanks for the help |
