Axiom vs JBL
Username: Philly_t
Hi every one:
How do Axiom and JBL speakers compare?
Thanks in advance for your thoughts!
Username: Project6
Post Number: 12665
Which model JBL against which model Axiom?
But in all fairness, it doesn't matter which one speaker people prefer, it is what you like that matter.
I like Axiom M60, M80 and the 22ti bookshelves over what JBL has to offer. Others like JBL...but listening will make short work of that.
Username: Project6
Post Number: 12666
oops, make that M22 bookshelf. Others think they are on the bright side.
Username: Westcott
League City, Texas
Post Number: 142
Berny is right. It really depends what you are used to listening to. If you grew up listening to direct radiating speakers like most people on the planet, Axiom may sound bettter to you. If you are one of the rare few exposed to horn loaded speakers as a youngster, JBL is a very well established and respected speaker mfg that has been around a long time.
You should be able to audition the JBL's readily as dealers are almost everywhere. Not so for Axiom so listening to both may be a problem before purchasing.
Good Luck!
