Bronze Member Username: Cricket674
Post Number: 43 Registered: Feb-07
Posted on what should my Autoroll options be right now I have everything on except for Dishnetwork autoroll is that right or wrong I have pansat 2500a clone. |
Bronze Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 12 Registered: Mar-07
Posted on What Bin? I have the 292T on mine with the autoroll OFF and you know what? The keys roll even with the autoroll set to off!! If you keep the autoroll off, you should get much fewer reboot problems. |
Post Number: 44 Registered: Feb-07
Posted on another thing what's the best bin for CS and can you give me the exact link to the site to download it, I need to download it to a CS 4000 pro clone |
Leesburg,
Georgia
Post Number: 14 Registered: Mar-07
Posted on Try: http://www.dssrookie.com/forums/ |
