Bronze Member Username: Jesse59672OK Post Number: 25 Registered: Feb-07 | http://www.topaudiousa.com/servlet/Detail?no=307 box would fit nice but its only 5/8 inch. i dont like the whole idea of a machine cutting the box out and it being assembled where i cant see it being done i dunno :\ |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11565 Registered: Jul-05 | build ur own..or get somebody to build one for ur subs specs |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 707 Registered: Aug-04 | ^^ Agree. Most prefabs arent built the strongest. |
Platinum Member Username: BestmankindWww.15inchwangers.comFI Audio BTL Post Number: 10560 Registered: Oct-05 | it would be hard to build that box in the pic. unless you are mark potts or phil salsibury. |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 710 Registered: Aug-04 | Im not saying that box would be easy to make but Im sure there is a box that would be easier to make and still fit in the vehicle. |
