New member Username: Atlantis_sweetPost Number: 1 Registered: Feb-07 | I have dell 600m and tried to connect it to my LCS using an S Video. I am not getting any signal.I have mobility radeon 9000 for my display settings. Can someone help me? Any help in this regard will be highly appreciated. thanks in advance. |
Gold Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 1588 Registered: Dec-06 | Did you make sure and set everything correctly in the menu in properties? |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1367 Registered: Jan-06 | go to ATI website ,get the latest "Catalyst Control Center" for your video card...then you can easy adjust your monitor(s) setting! |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1368 Registered: Jan-06 | https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questi onID=21578 |
Gold Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 1592 Registered: Dec-06 | Oh I thought he had that. Now that I read his post more clearly, I can see. Jen, would you mind fixing your profile to have more info on your computer? |
New member Username: Atlantis_sweetPost Number: 2 Registered: Feb-07 | I switched to S video on my TV. It says searching for signals. When I try to extend my desktop and move on the right extreme corner it seems to dispalying the media files. I am not able to find the drivers for my Radeon 9000. I dont know where i going wrong. thanks for the replies |
New member Username: Atlantis_sweetPost Number: 3 Registered: Feb-07 | I tried to update my driver. It says INF not found and could not complete my installation. Any suggestions as where I might be going wrong? thanks |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1372 Registered: Jan-06 | you no need driver for that! try to get "Catalyst Control Center" |
New member Username: Atlantis_sweetPost Number: 4 Registered: Feb-07 | Sorry I have Mobility radeon 9000 and i dont see any catalyst control center for the above set of dispaly control. Any suggestions to install |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1373 Registered: Jan-06 | call to the dell customer centre! let them *** the head.But I am sure, they will re-address you to ATI... |
New member Username: Atlantis_sweetPost Number: 5 Registered: Feb-07 | Thanks for your inputs. |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1378 Registered: Jan-06 | sorry,I tried my best! I am sure you have to adjust it from "Display Properties" |
