Bronze Member Username: Jesse59672OK Post Number: 38 Registered: Feb-07 | Any have some? I have a 99 camaro and i'm going to make a box myself. I dont know half of the sh*t i will need. I'm guessing some kind of epoxy resin and some mdf sheets. but other than that i'm lost i dont know exactly how i should go about building one its for a single 12 need it ported at least 2.5 cuft |
Gold Member Username: Extrmndor3IF U HEAR ME... I GOT KING K... Post Number: 3954 Registered: Feb-06 | ihave one i can take pics later its a cool box man im saking around 40 plus shipping. if u want pics i can take em like later like at 11 pm if u want let me know wat u think. oh by theway its juzz for 2 12's and its sealed |
Silver Member Username: Gh0st_31FL USA Post Number: 299 Registered: May-06 | You need a tablesaw, a jig or router, the mdf, screws, liquid nails/gorilla glue, and something to seal it (i used caulk.) oh and the wire terinal |
Bronze Member Username: Jesse59672OK Post Number: 39 Registered: Feb-07 | not interested in it if its for 2 12's.. cause i'm sure its not a 4+ cuft and sealed.. but thanks denny is building a box for a camaro kind of complicated for my first box? i dunno it will have alot of angles & cuts.. i've never really worked with wood before but i know people who have |
Silver Member Username: Gh0st_31FL USA Post Number: 301 Registered: May-06 | well I have a hyundai tiburon and I didnt have much problem making my first box. I just maade the back flat even though my seats are tilted back. Its almost not worth the work in my eyes. If its your frist box, dont even mess with the angles. Just a nice easy square box |
Bronze Member Username: Jesse59672OK Post Number: 40 Registered: Feb-07 | if i make it square it won't be 2cuft :| |
Silver Member Username: Gh0st_31FL USA Post Number: 302 Registered: May-06 | hmm ok then. Your best bet then would probly be to find someone to make it then. Look for logan he will hook you up. Heres some of his work https://www.ecoustics.com/electronics/forum/car-audio/330174.html |
