Username: Smoke05 Tucson,
Arizona
U.S.
Post Number: 120 Registered: Jan-07
Tuesday, February 27, 2007 - 05:37 GMT should i get the: infinity kappa 60.7cs or Mb Quarts PCE 216 which one is better for sq? thanks
Username: Nd4spd18 Southeast PA
Post Number: 588 Registered: Jul-06
Tuesday, February 27, 2007 - 05:38 GMT SQ is subjective. You need to listen to them to know which ones sound better to you.
Arizona
U.S.
Post Number: 121 Registered: Jan-07
Tuesday, February 27, 2007 - 06:01 GMT i dont have acces to either
Username: Alteraudiousa Concord
Post Number: 1465 Registered: Jan-06
Tuesday, February 27, 2007 - 06:03 GMT why those companies? There are better sets out there proven to have more SQ to them by buyers/users. Do you have an objection to other companies?
Arizona
U.S.
Post Number: 123 Registered: Jan-07
Tuesday, February 27, 2007 - 06:08 GMT well yes as long they are below $200
Post Number: 601 Registered: Jul-06
Tuesday, February 27, 2007 - 20:16 GMT CDT, Rainbow, and Focal make great components, I don't know what they have in your price range though.
Username: Gibson5469 Post Number: 157 Registered: Jul-05
Wednesday, February 28, 2007 - 02:38 GMT I'm a huge fan of MB Quart. They can get a little pricey though.
Post Number: 620 Registered: Jul-06
Wednesday, February 28, 2007 - 05:23 GMT ^^^^^ Those are known for having very harsh highs. I would recommend you hear a set before considering buying them.
Username: Warlok Orlando,
FL
Post Number: 235 Registered: Dec-05
Sunday, March 04, 2007 - 01:07 GMT Ive heard both of them (diff vehicles though, but of similar size and acoustical setup). I would go with the PCE's hands down. But, they are both nice speakers so you really cant go wrong with either of them. The PCE's will have a lot more lower midrange and midbass(IMO, which is something the Kappas will lack (also IMO).
