Kicker comp vr
Username: 2002civiclx2002
Evanston, Wyoming Usa
first post, tried to search but did not pull up any threads at all. but i am currently shopping around to upgrade my sound system. right now i have a cheap system. 800 total with 2 yr warranty and instalation from circuit city. i was 17 so my mom made the rules on it. anyways, im 18 now and can do what i please with my car. i am looking to buy 2 kicker comp vr 12's and a mtx 1000w amp. i will be running a sealed box, any input on this setup, or a better options? thanks.
Username: Thumping_corsica
Mi, Mi Unitd states
Post Number: 384
u could do much better on the sub choice.. whats ur budget and what are you looking for.. sql,sq, or spl?
Username: 40hz
N.C. Usa
Post Number: 115
ya ive always had kickers,and the cvr's dont sound that good to me.dont go sealed if you get them,they wont be loud at all.
Username: Spkrman
Chi town, IL U S A
Post Number: 185
CVR's are good sealed box woofers.
But, ported will be vastly superior as long as you get a custom box.. and not a fleabay special.
Username: Nd4spd18
Post Number: 434
and for $800 you can get a lot better than CVRs
Username: Oleg
Santa Monica, CA USA
Post Number: 366
I agree, CVRs sound great in a sealed box, but I'd say they can get louder if they were in a ported box. Great budget sub, hard to beat.
so what would you guys suggest on the subs then? and i also have the option of getting a 1500W amp.
