Forect menu problem
Username: Foxykleo
Post Number: 18
Guys..i have a problem with my fortec ultra for dishnetwork....when i go to the menu to put in new keys...some of the options like parental control is faded out..i can't get to it...can someone tell me what happened....or any suggestions on what the problem could be?
Username: Nikk
Post Number: 1340
liz...
which bin do you have???
I guess that in the new bin is not parental control, it is secondary pin......
Username: Doreenakadj
Post Number: 178
do a factory reset .. start over loading the factory bin file using a GTRom Loader. then load the most resent bin file with bl loader.... find the sats you want to scan and with any luck after you have found all the channels and stuff .. your parental control otpion will work btw ... the key roll should be turned off find the right updated keys and type them in. I hope this helps you out
Username: Lklives
Post Number: 7859
U cannot get to "parental controls" because U have NOT scanned any channels or uploaded a channel list, so your receiver has NO channels that need to have "parental controls"...so a scan should bring back the parental control option for U on the screen..
BTW...upload bin 290T also, its the latest...set the default key, turn autoroll ON, and let the latest keys roll into the receiver also...good luck!
No need to start all over from scratch either...
Username: Nydas
Post Number: 1944
liz : Think back. Did you do a factory reset? That is what it sounds like. Simply scan your satellite and you will see the faded parts come to life.
Username: Prfrmnj
Post Number: 2094
I've seen and read it all. Nalin - Why are you repeating what LK just said. Didn't you state that he knows nothing but yet you repeat what he says? Do you have nothign on your own to say and you have to repeat what people who actually know something say. I beat 99% of your post are nothing more then repeats of others. That's about the only way you can say something right. When you post on your own you show how dumb you really are.... Do I need to c/p more of your ignorance?
Username: Nydas
Post Number: 1945
PRFRMNJ : I post where I beleive the person can be helped. In this instance nobody had pointed out to Liz as to how it could have started (Factory reset) so she does not repeat her mistake. Go and read the posts again. I thought you were a lawyer and were able to see the evidence clearly and quickly.
Username: Prfrmnj
Post Number: 2098
There you go again thinking. That's gotten you in too much trouble. Get off the crack pipe. All you ever do is either quote others or give bad info...
Go ahead and post as much as you want. I'm just here to prove your ignorance and that I've already done!
Username: Nydas
Post Number: 1947
PRFRMNJ : It is you who hides behind LK's skirts all the time. Go and learn how to read English, before you call yourself a lawyer.
Username: Prfrmnj
Post Number: 2102
Obviously the one that can't read it YOU. I have never called myself a lawyer. I have a law degree and then some, but you are the only ignorant who calls me a lawyer. GO READ AND THEN COME BACK TO ME. Actually never mind! You are not worth it.... Have a nice life and you can count on my correcting your stupidity... Well not all of it. I don't have the time to correct you every 5 minutes...
Username: Nydas
Post Number: 1949
PRFRMNJ : But you do find time to make stupid posts on behalf of a friend who has the ability to post more than 7000 times. Just let people defend themselves.
Username: Prfrmnj
Post Number: 2106
Like I said, get off the crack pipe and on the meds you keep telling others to take. You really have no clue! Good night....
Username: Nydas
Post Number: 1952
PRFRMNJ: Since I do not drink or smoke, you must be referring to someone else - perhaps LK?
Post Number: 186
i think we will never really know what lizes problum was .. LOL i think we all scared her off. But if i may say something on her defence... she had to of had channels to begin with in order to notice that they are not working any more and needed new keys to fix the problem. ... so i am thinking ... she did a factory rest .. most women and men do if things are all screwed up with the channels ... so in doing so she needs to rescan the sats .. Or perhapse she got a bad bin and it screws her reciever up. if so .. then restart from scratch . and load the factory bin and so on .... but when all is said and done .. we are all right .. scaning for sats is the first thing to do... so..... what shall we argue about now?
Username: Foxykleo
Post Number: 19
- I do have the new bin 290...and LK I ALWAYS do scan and update my channel list..but right now thats one of the options that are faded out. so that doesn't help!
- Factory reset?? i haven't done those before..but i will give it a try...what is a GTRom Loader and the factory bin..thats 290 again right??
BTW Thanks Doreen ;)
Post Number: 196
liz are running a Pansat or a coned reciever? clones requier 290T real receivers run just 290. .. to get the right bins to redo your reciever I would go to dsscommunity and go to the right thread " pansat files" or whatever reciever you have. First get the factory bin. use the right loader that Applies to your reciever also found at dsscommunity. You can't use BLloader with a factory bin, but you can use bl loader 14 to flash the 290 bin after you flash the factoy bin.if you still need help just PM me and i will talk you through it in email and email you the proper files needed for your reciever.
Username: Nikk
Post Number: 1347
liz...
Check what I'm telling you...I have noticed that problem with some other people...in the new bin it looks like instead of "Parental Control" the name now is "Secondary Pin"
