Have new factory megasat installed new bin 290 and tried to put channel list on and nothing. Went back to factory settings and re-install bin and tried a blind scan. Just froze. what did I do wrong. I thought I did this before. Thanks
For any 2500 clone you need the bin X-85BL_DN_070203_290T_api from chancysand
Just get sure you are not downloading the bin file X-85BL_DN_070203_290_api that is for the original 2500
The "T" on the file means that is clone safe, if you have a clone and download the original bin it will kill your receiver and you will have to JTag.....
