How to port 2 subs......
Username: 40hz
N.C. Usa
Post Number: 109
whats the best way to slot port 2 subs in a single enclosure?Put 1 single port inbetween the 2 subs or put both subs side by side then put the port off to the side.oh the subs and port will have to fire the same way. and do i double the port area when running both subs in 1 box.the manual calls for 39 in of port in 3.25 cubes per sub.do i make it 78 in of port in 6.5 cubes for 2 subs.
Username: Oglejust
You aint bangin unless..., Il
Post Number: 1034
1 slot in the middle looks the best
Username: Logan__tille
Imortal Box Building
Post Number: 6027
subs side by side facing the front and port coming from the side.
Username: Kyle_lowe
Post Number: 174
top view Upload
Username: Oglejust
Post Number: 1037
^^^ x2 and logan ur a wh0re lol
Username: 40hz
N.C. Usa
Post Number: 110
ya logan,i just built a test box w/sub firing str8 into the cab w/port off to side.but the port is firing into another 3 sided chamber to catch the sound and keep it in the cab.the box is in the bed,i got a 12x32inch blowthru.i think the side chamber catching the port air is actually effecting the tuning so I,ll go with Kyles design,thanks guys
Post Number: 6049
lol fu*k you Justin...fu*k you:-)
