I downloaded bin X-87BL_07020 1_295_api after the download my reciver dosen show no numbers in front i so i cant work with it please help me is just a line in front going back an fort like when is restarting
You need to get the 295 bin from a different source, it seems to me that the bin you actually downloaded is somehow corrupted, do what McSunny says, reload the factory bin and then another 295 bin from a different source...
One more thing, when you get the bin from any site it is normally zipped, did you unzipped the file before trying to download??
The bin as you get it from any site must be named X-87BL_070201_295_api.zip, then you need to unzip it to get the working bin named X-87BL_070201_295_api.bin
LOL MC i did that 2 same result reciver dosent go to on just like u said knight riders light which best bin i can use now maybe this 295 n0t good and do i have to live aotorole on or of thx
It will be better if you can get the loader that Albino says, also get the bin again from a different source, I have found that there are some places that have corrupted bins....I got mine from www.ftabins.net
any one please help!! i have 290v1 Tivo BIN and it is keep on going out every now and then... I want to know if their is a new BIN that has been out since last time i check...Also i have the old loader too so please help THANKS
