Cool sat 5000 problem [need help!]
Username: Binhto
im a newbie so sorry if this is annoying you or anything but when the flashing does that i turn of my reciever and than turn it bakk on than put the bin in it works but it'll just flash again i cant go on the menu or anything is there something wrong with the reciever? :confused: :-(
if you know what is going on and how you can fix it.. if you can please write out the instruction
please and thank you so much ;)
Username: Lklives
Post Number: 7828
U must go to a real DSS site where they have the manuals and files...read the "RECOMMENDED satellite sites" thread here...then pick one...suggest Using the Coo*lsat home site..U have MUCH reading to do!
Username: Lklives
Post Number: 7830
[link removed] (C00LSAT and All receivers)
Username: Jelv
Flusshing, Ny United states
do any one have the new codes for the coolset 5000
