New member Username: InvinciblePost Number: 9 Registered: Jun-06 | Hey LK I need to know MAX 2000 is a clone of which reciver and if there is any bin i can use with that reciever to recieve echostar channels. Any Help would be greatly appreciated... |
Silver Member Username: LroyPost Number: 187 Registered: Aug-06 | I think it is a clone of the Digiwave 7ooo... |
New member Username: Cricket674Post Number: 9 Registered: Feb-07 | hey LK I also need help, where can i get the latest bin for a pansat2500a clone. |
Silver Member Username: Crazy_greekPost Number: 636 Registered: Jul-06 | Hey 4M Are you sure you are not talking about MRX-2000? |
New member Username: HangmanPost Number: 7 Registered: Jul-06 | can some one please help i have a csat 5000 and i cannot get all the channels i'm missing most of the channels |
Bronze Member Username: InvinciblePost Number: 11 Registered: Jun-06 | Hey Kevin Thanks for the response but on the front of the box it says MAX 2000 and You can actually see the reciever if you wanna have a look at http://www.freetoairdvb.com/max2000.asp Thanks again for the reply and I hope to get the answer and be able to use the reciever some time soon.... |
Silver Member Username: Crazy_greekPost Number: 649 Registered: Jul-06 | Hey 4M The only thing that I came up with, is that the Max-2000 is actually a ST-1000 View Blackbird. I didn't see any new Bins out there. |
Gold Member Username: LklivesPost Number: 7837 Registered: Jan-06 | ask nalin..she knows everything!...LMAO... |
