KENWOOD KDC-MP435U demo mode
Username: Gre0005
Shepparton, Victoria Australia
i go to stand by mode.. hit menu botton, scoll down to demo mode. and it is set to on and it wont go to off
helpp
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1374
take the battery -(minus) off...5 min you good !
Username: Gre0005
didnt work thanks anywayz
Username: The_image_dynamic
San Diego
Post Number: 389
What Jen said usually works. In this case it didn't. The trick is: after you do what you described above, you have to hold down the button that changes the demo mode from on to off for a few seconds before it will exit demo mode.
Username: Gre0005
thanks, it worked. what does demo mode do anyways? it didnt seem to make a differents
