Speakers with my new HK AVR 445 ?
Username: Ssin680
Post Number: 8
Hi,
As you probably know, I just bought a Harman Kardon AVR 445 A/V Receiver.
I'm now looking for new speakers and the following are available :
Klipsch / Paradigm / Polk / Athena / Bose
Again my room is 12X18 and I'll mainly use the system for Home theater (85%).
What power range should i look for ?
Thanks in advance !
Charles
Username: Ssin680
Post Number: 9
I forgot,
JBL would also be available.
Charles
Username: Project6
Post Number: 12937
Unless you are enamored by the sound of Bose, I would take it out of the equation. Have you listened to any of these speakers?
Klipsch, Polk and Athena play very well with HK. Paradigms are excellent speakers, I just do not prefer them paired with HK.
What is your budget?
I wouldn't worry too much about power range, the speakers you mentioned above can handle the HK.
Username: Ssin680
Post Number: 10
Hi,
My budget would be around 1500$ - 2000$ CAN $ so between 1300 and 1700$ US.
I was offered a Polk package (RM20). This is a 5.1 set so i could add a pair of speakers in front or as surround speakers to get my 7.1
I could also go with the Cinema CT 110 Paradigms and either add a pair of surrounds or upgrade the Center/Left/Right to Cinema 220 ?
Or I could take a look at Klipsch or Athena to see what they offer in this price range.
Charles
Username: Project6
Post Number: 12984
Polks play well with HK.
Username: Hawk
Highlands Ranch, CO USA
Post Number: 1181
Charles:
Check for an Athena dealer near you--it is a Canadian company, so I have a hard time believeing that you can't find a dealer. Athenas would be the best match followed closely by Klipsch.
Here is the Athena Dealer locator page for your use:
http://www.athenaspeakers.com/v2/dealers.php?ident=Dealer+Locator
Username: Ssin680
Post Number: 14
Hi,
It's a done deal !! I listened to a few ones and I went with Klipsch
RB61
RC52
RS42
RPW10
Since i did not receive my Hk receiver (should be monday) I just replaced the old Denon ones on my Denon Receiver and what a huge difference already !!!
Thank you
Charles
