i loaded the latest bin for the sonicview 1000 and now i cant hear anything. i can see the picture but i cant hear. if i turn the power off from the back and turn it on the volume comes on for like 2 seconds and then it turns off. what should i do to fix this/
I'm not sure bob. I loaded the 250 bin into 3 receivers with no problems with neither one, autoroll works fine. I see that there is a 251 bin out there, haven't tried it due to the 250 not giving any problems. Try factory reset, then try the 250 bin.
