Wire
Username: Kickerman
Post Number: 81
i know that this is the wrong section but i need to know what would be better. would i be better of getting the klm wire from knukonceptz for $70.00 shipped with a 250 anl fuse. or get the kicker wire that has a 300 anl fuse with two distribution blocks for $98.00 shipped
Username: Stnorris
Davenport, IA US
Post Number: 2014
r u gunna need the distrubtion blocks? and what amp(s) u gunna be running?
Username: Kickerman
Post Number: 82
well i will have 3 amps two kicker 1200.1 and one kicker 350.4
Username: Kickerman
Post Number: 83
bump
Username: Stnorris
Davenport, IA US
Post Number: 2016
kicker kit would be the way to go then...ull need the dist blocks and a 300anl fuse sounds just about right.
or u can get the knukonceptz wire and fuse and then buy seperate dist blocks?
Username: Kickerman
Post Number: 84
ok i think i will go with the knukonceptz one last question i can i ground all three of my amps through a dist block
Username: Stnorris
Davenport, IA US
Post Number: 2019
do u got aim...my sn is lifelessinabox
Username: •cam•
Post Number: 87
did you buy those off ca.com? cuz i saw some guy was selling those three amps.
