HELP HELP HELP
Username: Jjfox23
Toronto, On Canada
Hi,
I need some help understanding why my viewsat platinum is not showing properly and the signal is low and next to none.
i have the latest Bin and it loads okay but when i try to download the channels i get 150.any help would be appreciated.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1180
Connect the coax directly to the reciever and check your quality,if low re-adjust your dish for best signal.If your using a switch,check the switch settings and switch condition.they can go bad at anytime for no reason.Since your getting aprox 150 channels ,depending on what sat your aimed at,I'd lean toward a poor dish alignment,or coax connections.Really need more info on your setup to help you further.
Username: Crazy_greek
Post Number: 631
Hey Smith
Here a list of Satellites & Channels
(Plus or minus)
Nimiq2 120
Nimiq1 380
Echo 3 125
Echo 8/10 377
Echo 7 352
Echo 9 134
Galaxy 25 200 FTA
