CW-100R Video Review this will work on other fta receiver
Username: Brucester
Post Number: 280
Found this on another site. It's a short video review of the upcoming Captiveworks CW-100R (DVB Recorder).
http://youtube.com/watch?v=zccpvUpLwyg
Username: Brucester
Post Number: 281
CW-100R Specs (PVR add on unit)
Coming next week.
CW-100R Captive Works PVR add on
Use this to add a PVR function to your Captive Works 600S and Captive Works 600S Premium Series FTA receiver (or other receiver as well). For Captive Works units it will also add USB bin loading function and offer better integration with guide for PVR function. With Captive Works Receiver you can schedule a show through the epg and when the time comes, the recorder will automatically start recording and when it finishes, the recorder automatically stops.
You will need to add your own Storage Space, it will accept USB 2.0 Compliant External Hard Drive or USB Flash Drive.
Suggested Retail $129 alone and it will also be priced lower as part of a combo package including a Captive Works 600-S Premium.
Attached you will find complete specs and pics.
