Username: Kickerman Post Number: 81 Registered: May-06
Friday, February 16, 2007 - 18:55 GMT i know that this is the wrong section but i need to know what would be better. would i be better of getting the klm wire from knukonceptz for $70.00 shipped with a 250 anl fuse. or get the kicker wire that has a 300 anl fuse with two distribution blocks for $98.00 shipped
Username: Stnorris Davenport,
IA
US
Post Number: 2014 Registered: Apr-06
Friday, February 16, 2007 - 19:00 GMT r u gunna need the distrubtion blocks? and what amp(s) u gunna be running?
Username: Kickerman Post Number: 82 Registered: May-06
Friday, February 16, 2007 - 19:04 GMT well i will have 3 amps two kicker 1200.1 and one kicker 350.4
Username: Kickerman Post Number: 83 Registered: May-06
Friday, February 16, 2007 - 19:11 GMT bump
IA
US
Post Number: 2016 Registered: Apr-06
Friday, February 16, 2007 - 19:13 GMT kicker kit would be the way to go then...ull need the dist blocks and a 300anl fuse sounds just about right. or u can get the knukonceptz wire and fuse and then buy seperate dist blocks?
Username: Kickerman Post Number: 84 Registered: May-06
Friday, February 16, 2007 - 19:21 GMT ok i think i will go with the knukonceptz one last question i can i ground all three of my amps through a dist block
IA
US
Post Number: 2019 Registered: Apr-06
Friday, February 16, 2007 - 19:30 GMT do u got aim...my sn is lifelessinabox
Username: cam Post Number: 87 Registered: Nov-06
Friday, February 16, 2007 - 20:11 GMT did you buy those off ca.com? cuz i saw some guy was selling those three amps.
