I'm trying to download bin 2.93 in my Ariza 700 but it doest seems to start downloading frm the loader. Just gets stuck on 0% and there no activity in the the reciver. Anyone got any idea?
try a factory reset before you try loading the new bin....i had the same problem ..and Angel told me to do the reset...and it loaded right away after that.. c/p from other site this might work for you
go to a site that has files i go to dssrookie*com or al7bar*com free gust register and you will get the ancer you are looking for others with that box will help you if i see something all bring it back ps dot forget to chang the star ti a dot have a nice day
I have ariza 700. I am getting no signal. I have done factory flash, loaded bin 2.81 then 2.91 then 2.93 but none worked, it still shows 28% level and 0% quality & when I scan , it fails. I have tried another box and it worked fine, so I believe cables and dish are ok. Could it be a hardware problem or software ? P.S: If I shake coax cable a little bit, level goes upto 45% but quality still 0% and scan still fails. please any suggestions ?
