New member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 5 Registered: Feb-07 | i have 2 12" kicker compvr's that is in a sealed box and the amp is a alpine (dont know what kind if you can tell me from the pics that would b nice) that has 350 watts. is this a good setup for what i have or no | |
Silver Member Username: Freezeman_7EveryThing I Own is FO..., OK U.S.A Post Number: 704 Registered: May-06 | i think those subs are prolly a bit under powered... uhh... is that 350rms or peak??? is it a mono amp??? are u lookin to upgrade or what?? | |
New member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 6 Registered: Feb-07 | if the amp isnt that good but the guy said it is perfect and i think it is 350 rms aand is a mono amp | |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1861 Registered: Jan-06 | http://www.cardomain.com/item/KIC07CVR124 if these are the subs, then they take 400rms EACH. |
New member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 7 Registered: Feb-07 | ya but i think mine are newer than that 1 | |
New member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 8 Registered: Feb-07 | so what type amp should i get if i have two of the newer 1's and what size wattage should i get for it. | |
Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 261 Registered: Jan-07 | im srry dj but thats the newest model 07 ^^^ | |
Gold Member Username: CenusHicksville, Ohio Post Number: 2931 Registered: Jan-05 | do you have the one with a yellow cone and black center piece with kicker, written in it, if so those are 300wrms each. | |
Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 262 Registered: Jan-07 | http://www.cardomain.com/item/KIC07CVR124 just like wolfman posted ^^^^ he said there newer than these but these are the newest he might mean older models? there 400rms a piece decent subs but could get better my dad has 2 of em with same amp as mine in his 99 16 pass dodge van lol |
New member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 10 Registered: Feb-07 | ok this wont upload any of my pics WTF i would show you but i cant. ill try to describe it though. it looks like an oval with a little wave cut out of it(that is red) and the main sub color is grey | |
Bronze Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 11 Registered: Feb-07 | how do i load pictures this is really pissing me off how do i change the size of my photo | |
Bronze Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 12 Registered: Feb-07 | ok i think this might work | |
Bronze Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 13 Registered: Feb-07 | OMG WTF IS UP WITH THIS SH1T IT IS REALLY PISSING ME OFF. F*CK THIS SH1T MAN IM GONE FOR THE NIGHT
Bronze Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 14 Registered: Feb-07 | here are some more i got off the internet
Bronze Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 15 Registered: Feb-07 | yay that worked so heres the alpine amp that i dont know what it is so if u could tell me that woulde be nice
Gold Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 1230 Registered: Dec-06 | I use paint and save it as a Jpeg... |
