Viewsat plat.down
Username: Danoh
Post Number: 62
anybody else down?did they just do a key change?
Username: Canndy
Www.livefta.com, Www.livefta.com Www.livefta.com
Post Number: 262
BEV KEYS [link removed]
Bev: Last: Feb 4 18:00PM
00, 86: D9 F0 47 DC 74 DB FB 07 7A 7B 0B A9 BC 64 48 5A
00: D9 F0 47 DC 74 DB FB 07
01: 7A 7B 0B A9 BC 64 48 5A
01, 96: 22 4E 61 52 C6 96 C0 4F 7B FA 39 DE 88 C7 31 81
00: 22 4E 61 52 C6 96 C0 4F
01: 7B FA 39 DE 88 C7 31 81
[link removed]
Username: Danoh
Post Number: 64
thx the keys r working. i had a problem with the picture slow motion or something like that.just turned off and back on and everything seems 2 b alright.
Username: Jedimastermopar
Post Number: 42
Tried those keys and they don't seem to work.
Username: Gastrognome
Post Number: 18
keys change
[link removed]
Username: Jenn25
we down need new codes
Post Number: 43
no dice on the ones posted at tvkeyz
Username: Jenn25
no, those arent working, any new codes out there
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 759
Dish Network 02/02/07 09:37 pm
00: E3A66BC62665828561C4BA8D1C62EF45
01: EF6F7D06203CB417774247352AAB3971
Bell ExpressVu 02/04/07 06:40 pm
00: 2AE22A1DEF3747D81835730D07DE092D
01: 9E2ECEDC60151296C7D4383D0D2A2374
Username: Jenn25
thanks working now
Username: Hshakarchi
Post Number: 97
Hey dan kubesheski
Why dont you download the new Autoroll fix Viewsat Platinum/Lite (DBPSW-070202P B1 AR Fix and not worry about changing the keys..
follow this link and dowload the Zip ..
http://www.livefta*com/forums/t2589-viewsat-platinumlite-dbpsw070202p-b1-ar-fixspan.html
-Dont forget to change the(*) with (.)
Username: Jenn25
any new codes out there?
Username: Jenn25
Post Number: 7
im having trouble with these codes, vs wont take it. any suggestions
Username: Jenn25
Post Number: 8
hi again, trying to put new codes in, machine wont let me go past the nagra screen to put the codes in, any suggestions
CANADA Charlatan...
Post Number: 849
