i need help for 110 and 119
Username: Asifali418
Lodi, Ca Usa
Post Number: 29
hi i m using view sat extreme.i use 3 satelite.
1.119
2.110
3.148.before when i buy this reciver its work very good on three satelite.but now its not work my antena setup is port 1 is 119 and port 2 110and port 3 for 148 .but in port 2 i have no sagnle right nowi last both sagnal like quilty and the other one too .its like LNB power is off.but its on.and when i go to the atena setup on 110 i put it on port 2 and i take outcable and then put it backe so the sagnal come backe and hen i save it and exit it then i last it again.before i useview sat diseqc switch and i think in it go water so its not work then my friend give me new pansat diseqc switch ,but its not work to plz help me,remmber when i bring dricet cabel only110 and 119 so its work good like port 1 for 119 and port 2 110 i use dish 500 antena with 2 lnb.thnkas
Username: Prfrmnj
Post Number: 2032
Nike - The fact that you took off the cable and put it back in with your unit powered one leads me to believe you just burnt you switch. You CAN NOT remove cables from your receiver with the receiver still plugged in the wall -- let alone the receiver powered on!
Change the switch
Lodi, Ca Usa
Post Number: 32
i change the switch i buy brand new switch but its still not work.thanks
Username: Prfrmnj
Post Number: 2047
Nike - Reflash your unit with original bin then reset Factory Settings. After that you'll need to configure your antennas and do a scan. Once scan is complete reload latest bin for xtreme and turn to channel 105 or 200 and wait for the keys to roll in.
Username: Nydas
Post Number: 1869
nke usa: What Switch do you have and what LNBs?
Lodi, Ca Usa
Post Number: 33
i use view sat switch and i have pansat 2700 too.and u se dish pro LNB 500.where i got the
original bin .thanks
