Pansat 2800A - Best LNBs for 110/119 and 82/91?
Username: Roboace
Hi,
I installed satellites in the past but I need some advices from experts about these LNBs.
This is what I have:
2800A Pansat Receiver.
2 Dish Network 500. Each dish have the U-shape arm that can hold 2 LNBs.
1 Dish Network Plus LNB. There are two 2 LNBs.
1 Dish Network Pro LNB. I only have one.
4 Dish Network Legacy LNBs.
4x1 Pansat DisEqc switch
DP 34 switch
I want to get these satellites: 110, 119 , 82, 91.
Given the equipments I have, what would you use to get 110 and 119?
How about 82 and 91?
Would you use the 4x1 switch or use the DP 34 switch?
Also, in the Pansat Antenna Set Up Menu, there is a choice of Standard, Dish Pro, Universal 1, Universal 2, etc.
Should I use "Standard" or "Dish Pro"?
Any help will be appreciated.
Username: Wakenbake
Post Number: 323
i would use one dn 500 dish with 2 legacy lnb for 110,119.
and the other dn500 w/2 legacy lnb for 82,91.
use the diseqc
standard lnb in installation
