PANSAT 2700A - Bin 292 -Autoroll Not Working
Username: 1llu5ion
Post Number: 24
Hi Every one,
I have Pansat 2700A with bin 292.
The auto roll doesn't work and I have to enter the keys manually.
Is it the case with every one or just my receiver?
Any help would be appreciated.
Username: Chrisduclo
Post Number: 16
295 is the current autoroll bin.
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 825
295 IS rolling like a river.
I found a few glitches - but not sure if it is a diff kind of problem, and it's no problem for viewing.
Username: Pathfinder191
Post Number: 169
Hi all,
My friend has Pansat 2700. Everytime he turns it on using his remote, a message appears EPG Loading press OK or exit. Is there any way to bypass this option?
Thanks in advance.
Username: Big_fat_j
POTTSVILLE, STONEYTOWN GREEN-LAND
Post Number: 337
Press Exit.
Username: Big_fat_j
Post Number: 338
Or dont turn it off.
Post Number: 170
Hey Herb,
Thanks man. He wants to bypass this option so when he can turn the power on, he can see the picture directly. The reason is he has his VCS connected with his receiver and usually he records his favorit programs by setting the time on both (receiver and VCR) Now when the receiver turns on automatically, all his VCR records is a screen with "EPG Loading ... Press OK or Exit".
