Help!
Username: Rated08
Hey guys, i have a viewsat 2000. hasn't given any problems. My only complaint is that i have to put in codes everytime they change. A friend of mine is the one that set me up, he even would fix it to autoroll with a new bin or whatever. But i don't want to bother him any more. I wonder if it's possible if i can fix these minor problems myself. Im cool with typing in the new keys but would like to make it easier and not bother with that all the time. how can i start?
Thanks, yall to a great job!
Username: Steph_raven
Les Cedres, Quebec Canada
Post Number: 50
Johnny,
look to see if your autoroll is on. if it is and your have to enter the keys manually, then download the latest bin for your viewsat from a good site that have the bins for your reciever.
viewsat 2000 is the ultra? the same model i have. the latest bin i'm using is PFTAUSW-070206U
on BEV. my autoroll in working fine. you can load the bin 2 ways. usb or by cable. hope this helps...i'm not an expert....yet...lol
Username: Rated08
thanks for the info stephane, its a viewsat 2000 platinum ive had it about a year. don't know if thats older or newer. What website do you go to for the bin files? thanks
Username: Roxxie
Post Number: 9
Hey Johnny, I like this site below, they are helpful and nice there. Roxxie-
[link removed]
Username: Rated08
Thanks roxanne, i'll check it out.
Post Number: 51
Johnny,
the most recent bin for the plat is DBPSW-070206P
the ones i use the most are:
www.dsstester*com
www.dsscommunity*com
www.dsscentral*net
replace * by .com/net .
there are others but those are the ones i use.do you have you cable to connect to your pc?
you will also need the loader2 software to load the bin in your receiver available on those sites
g luck!
Username: Rated08
Post Number: 8
i dont think i have that other cable, should i just buy a usb cable then?
Post Number: 52
no you need the db9 cable, the vs plat does not have the usb port.
Username: Rated08
Post Number: 9
ok, i'll check into it. thanks guys. hopefully will talk again.
