Kevin previe
Username: Volfenhagking1600
I WILL be 15 Wangin
Post Number: 318
can i take a look at that RE SX box
Username: Frkkevin
Post Number: 3051
which lol?
ports on the side.. you choose either drivers or passengers..
tuned to 45hz but you can build a drop in for daily to tune it down.. i can help you with length and measurements if need be
external dimensions 16(h)x28.5(w)x23.25(d)
its coating in rubbercoating and could prolly use more in some areas.. i can do a finish spray with what i have left but its a nice box.. 1.5" front baffle with 1 coat of fiberglass resin on the inside.. just tired of it sitting around.. i have 3 boxes sitting in my apt
I WILL be 15 Wangin
Post Number: 320
is that the one for the SX?
I WILL be 15 Wangin
Post Number: 321
i dk the one that u said was used on a TermLab metered at 145
Username: Frkkevin
Post Number: 3055
all my boxes did 145+ .. lol.. that one and the SX did a 145.3dB with 1000rms..
