290t question
Username: Imnycusa
Post Number: 59
290t bin is split into 2 bins; one for DN and other for BEV. So, this means the bin for DN wont bring any BEV channels?
Username: Asharfi
Post Number: 536
Yes
Username: South2
Post Number: 19
Is 290t DN bin working for the internationls? I have sat 148. Thanks in advance.
Username: Nydas
Post Number: 1780
Gary: People have complained of missing some Indian channels on Echo 3 (61.5W) with 290T. The same is probably true of 148W. You may have to revert to 289T.
Username: Hanz
Post Number: 250
On DssCommun*ty downloads page, I'm looking for the 289T for my Pansat 2500 clone and I come across these other files like "Pansat 2500 AutoRoll Bug FIX", and "Pansat 2500 Autoroll Fix". What are these files exactly? Do these files fix the autoroll issue that is common with the 290T and 289T bin files?
Username: Chatau
Montreal, Canada Qc Canada
Post Number: 22
Hi.I have FortecStarUltra and 290T Bin ,working nice BEV 91 W . Not working BEV 82 W ,why?
Username: Maro
Post Number: 10
can somebody tell me how do we get into the nagravison on the new file
X-85BL_DN_070203_290T_api.
thanks
Username: Asharfi
Post Number: 539
Follow these steps:
1. Menu
2. Parental Control
3. Second Pin and enter 1668
4. You'll see Nagravision
But, Nagravision doesn't work anymore. If you wanna enter keys, you have to go into Nagravision 2.
Username: Dishlover
Toronto, Ontario Canad
Post Number: 36
When 290T dpwnloaded it shows 4 file 2 with Jtag for DN & BV and two without Jtag. Which one has to be flashed to receiver wit Jtag or without it. Thanks in advance for answer please.
Username: Prfrmnj
Post Number: 2006
Tamara - Don't flash the ones that say Jtag. you need the other files. You will only flash either the DN or Bev version depending on what provider you are pointing at.
Username: Dishlover
Post Number: 38
Thanks PRFRMNJ
