Silver Member Username: PitbullguyChicago, Illinois I Eats Beats... Post Number: 708 Registered: Oct-06 | Okay i can't tell if this HU on crutchfields website is the Pioneer Premier 680mp, or a slightly different model.....The pic they show looks EXACTLY like the 680mp as far as i can tell but they call it the "6800mp" and the extra 0 is making me paranoid...i'd like to order the one off crutchfield cause they give you free installation info and wiring harness and stuff. The unit in question: http://www.crutchfield.com/S-f2WDOO5qE5o/cgi-bin/ProdView.asp?g=300&I=130DEHP680 An example of a true 680mp: http://cgi.ebay.com/NEW-PIONEER-PREMIER-DEH-P680MP-INDASH-CAR-CD-MP3-PLAYER_W0QQ itemZ170078397491QQihZ007QQcategoryZ39752QQrdZ1QQcmdZViewItem |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 5681 Registered: Feb-06 | One is a Premier and one is just the basic pioneer. |
Gold Member Username: BlainewPost Number: 2148 Registered: Nov-05 | its the pioneer version.....less preout voltage that unit at crutchfield is a pioneer.... not the premier version pioneers have an extra 0 at the end of the model number |
Silver Member Username: PitbullguyChicago, Illinois I Eats Beats... Post Number: 709 Registered: Oct-06 | so is it worth it to get the premier instead off ebay?? what's the real significance of the preout voltage difference? |
Gold Member Username: BlainewPost Number: 2150 Registered: Nov-05 | get the premier....it better, more volts means a stronger signal to the amp |
Platinum Member Username: Rovin1 12 Atomic ... Post Number: 10662 Registered: Jul-05 | premiers has a 2yr warranty vs 1 yr for reg pioneer if either is bough through a authorised dealer premier always have a few extra features too my advice go to pioneers site & open each model in a separate window & do a side by side comparison to see 4 urself ...... |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1799 Registered: Jan-06 | yes premier does have a longer warranty, but I think that the warranty on both only applies if it is installed by an authorized dealer too. Still the premier is the better one and usually only costs slightly more. |
Silver Member Username: PitbullguyChicago, Illinois I Eats Beats... Post Number: 710 Registered: Oct-06 | the premier 680mp is like $200 shipped off ebay, new in the box. I think i'ma do that and get the harness off crutchfield. |
