Possible to mix ohm loads???
Username: B00m_b00m_mobile
Cali USA
Post Number: 8
Please help I'm a noob if you can't already tell from this question. Is it possible to run a 4 channel amp at a 4 ohm load for 2 of the channels and at the same time at 2ohms for the other two channels???
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 1126
Yes, as long as it's 2-ohm stable.
