Bronze Member Username: Smoke05Post Number: 58 Registered: Jan-07 | im planning to install 1 jbl 1200.1 and a phoenix gold 200 rms 2 channel, so here is the question. should i buy 1 or 2 amo kits, and speaker wire... what do i need. thanks |
Bronze Member Username: MmaudioconceptsMurray, KY Post Number: 23 Registered: Jan-07 | u need two amp kits...and if u want a distro block |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11408 Registered: Jul-05 | u dont need 2 kits....1 kit...power distribution block, a ground distribution block and an extra set of patch cables and remote wire..and ur done |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 5651 Registered: Feb-06 | Yep |
Bronze Member Username: Smoke05Tucson, Arizona U.S. Post Number: 68 Registered: Jan-07 | thanks,hope that will be cheaper |
Bronze Member Username: Smoke05Tucson, Arizona U.S. Post Number: 71 Registered: Jan-07 | will this amp kit work for either the jbl or fg? http://sonicelectronix.com/item_7941.html |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4118 Registered: Dec-05 | go with 2AWG or thicker |
