Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 32 Registered: Jan-07 | Does anyone no any good sites that i can give them the specs on my sub and they will make a quality good box for my subs or does anyone know any good places to buy boxes |
Silver Member Username: Rosrock2000Notre dame!USA Post Number: 269 Registered: Dec-06 | what sub? |
Gold Member Username: J_baby15Kentucky Post Number: 1237 Registered: Feb-06 | theres a couple sites that make really good boxes but they're pretty expensive. ppl on here can help u design one to build urself if u want, theres also a couple that may build one for u a lil cheaper than a site would. |
Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 33 Registered: Jan-07 | i am goin to get 2 alpine type r dual 2 ohm subs |
Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 34 Registered: Jan-07 | aight thanks jordan anyone else no any sites i could buy a good quality box |
Gold Member Username: CtmikeCt. Post Number: 3326 Registered: Feb-06 | http://www.woodlawncabinetry.com/index.html http://www.spkrman.com/ |
Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 35 Registered: Jan-07 | Well i am sorta on a budget so idk wont those custom boxes cost a ton i want a good box for like 175 and under are there any good boxes for that |
Gold Member Username: CtmikeCt. Post Number: 3329 Registered: Feb-06 | either make one yourself or have one made. couple of people here make them for others. start a thread for one. but even going to an audio store, unless they're complete as_holes, you should be able to get a dual ported box for that price. |
Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 36 Registered: Jan-07 | aight thanks |
Silver Member Username: Phil_salisburyPost Number: 170 Registered: Sep-06 | Matt, Shoot me an e-mail with the maximum dims for the enclosure and spec's you require for it. I'll hook ya up. |
Bronze Member Username: TallaballaLino Lakes, MN United States Post Number: 37 Registered: Jan-07 | aight phil whats your email adress |
Silver Member Username: Phil_salisburyPost Number: 171 Registered: Sep-06 | woodlawn.cabinetry@verizon.net |
