Bronze Member Username: GarciagPost Number: 71 Registered: Jul-06 | what do you guys recommned im thinking either 1 15 cvx or 2 12 cvr i wanna be able to use my kx 1200.1 its stable at 1 ohm any suggestions, links for other subs would be great |
Silver Member Username: Sinful_systems70Post Number: 309 Registered: Nov-06 | http://www.edesignaudio.com/edv2/index.php http://www.reaudio.com/ https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=1545cbc166a50fe/shopdata/index.shopscript |
Gold Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC VP of 15 Wan... Post Number: 1037 Registered: Feb-06 | If you're trying to keep within Kicker, I'd go CVX for sure, but if not it's a lot to choose from with that amp. Look around at DD, Fi, AQ, RE, SI, etc. |
Silver Member Username: Sinful_systems70Post Number: 311 Registered: Nov-06 | I have heard that that amp puts out major wattage at 1 ohm, something like 1300-1450 or something like that. Someone will see this and give you an exact #. ED Ov. series is great SQL (Elemental Designs) Fi BTL, Q, SSD are all better than the subs you mentioned. RE Audio also makes great stuff but if you want the ultimate than go with DD or Treo. JMO |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3434 Registered: Nov-04 | ascendantaudio.com |
Gold Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC VP of 15 Wan... Post Number: 1042 Registered: Feb-06 | Well, My KX1200.1 does 1447 at 1 ohm! |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3392 Registered: Jul-06 | being underrated like a b!tch FTW! trell...how do your 2 15"sd2.5 hooked up to a kx1200.1 sound...im looking at that same setup in the near future if i get an suv |
Gold Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC VP of 15 Wan... Post Number: 1051 Registered: Feb-06 | don't know yet Yanks, the KX hasn't got here yet! |
Gold Member Username: Denali_on_22sSSX, Tenneki US of A Post Number: 1305 Registered: Feb-06 | not all birthsheets are the same sinful systems... |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3399 Registered: Jul-06 | oh ok trell...well you let me know how it is bud...i want some numbers too if its possible... |
