Building Box....Woofer Xmax?? Muddy, Chad, any1?
Username: Chevyfan502
Post Number: 70
On my build plans http://www.subwoofertools.com/forum/ported-box.asp?Ew=18&Eh=22&Dia=6&Xmax=20&Vd= .12&NumW=2&Vb=3.5&Fb=38&Qts=&Vas=&Fs=&CE=0 the woofer xmax is set at 20mm ....is this where i would want it for tuning? again my subs are DD2512a's on 1200rms....box is 38hz...thanks
Www.15inchwangers.comFI Audio BTL
Post Number: 10076
that is a big box for a 12. is that what dd recomends?
Post Number: 71
2 12's......my last was 4.0 cubes tuned to 35hz but i have space requirements in this vehicle and i wanted it tuned a little higher
Post Number: 10077
i'd say do it. it would sound good still. what car is this box gonna go into?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3795
that'll work. id actually do 4cuft. are you doing subs back and side port?
Post Number: 72
its going into a reg cab chevy truck between bucket seats where the console would be, subs facing up, slot port will be on the front of the box by floor blowing toward four wheel drive shift lever
Post Number: 3797
something tells me you should do port back....
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 1253
^^X2
Post Number: 73
do u mean face the port against the back of the cab?? ...there would only be an inch or 2 between the port and the back of the cab
Post Number: 75
bump sry to continue bumpin this, its just im about done building the box right now, and im goin to mount it soon, sooo....
Post Number: 3809
can you move it forward some so it has 4-5 inches?
Post Number: 77
bump...
Post Number: 78
my bad for tha bump....no i cant...so what should i do
Post Number: 3810
well if the port forward is the only thing you can do then thats what you do lol.
Username: Oglejust
You aint bangin unless..., Il
Post Number: 842
yep^^^
Post Number: 79
well what is worse about that, thats what im tryin to figure out....but yea thanks everybody
