Upgrading from 2 p3s...suggestions please.
Username: Quig
Pittsburgh, Pa Us
Post Number: 279
aright right now i got a hifonics bxi1206d, im looking to keep that along with my box, slot ported, 4.3 cubic ft, tuned@ 32 hz.... right now i got 2 rockford p3s... im looking to sell them and buy 2 12s... what im askin is will it be worth it to upgrade to a better quality, will i hear a difference in db.
Username: Rvlacos
DD 3512 United States
Post Number: 1608
yes you will hear a difference, but we need to know ur budget and if u want SPL, SQ, or SQL? also its always better to build a new box to the subs specs.
Username: Quig
Pittsburgh, Pa Us
Post Number: 281
sql, and budget... looking at maybe 500-700 total... and is it posssible to just go with 1 18" and sound better then this setup? ported box of course.
Username: Ctmike
Ct.
Post Number: 3358
are you thinking of replacing that amp soon? if sticking with that amp you could get, to name a few:
2 dd 1012's
1 dd 2512 or 2515
1 fi ssd or q
1 si mag
1 mmat p3.0
1 mmat dreadnaut
1 ss rl-p 12" or 15"
1 crystal comp 12" or 15"
Username: Quig
Pittsburgh, Pa Us
Post Number: 282
What you think about these.....
1 15" memphis mojo
1 18" Mmats JUGGERNAUT
1 18" RE Audio SX18
any other suggestions or more then welcome.
Username: Ctmike
Ct.
Post Number: 3359
you will definately need a bigger amp for those. and unless you buy offline a bigger budget, at least for the juggernaut. not sure on msrp's for the other two. and do you already have a charging system upgrade?
Username: Quig
Pittsburgh, Pa Us
Post Number: 283
used juggernaut on ebay for 390 shipped... and no i dont have upgraded chargin system, just 2 batterys....
Username: Ctmike
Ct.
Post Number: 3361
that's a good price, think the msrp is about $1000. depending on the size of your alt. now you might want to think about getting a ho alt.
Username: Quig
Pittsburgh, Pa Us
Post Number: 284
wat wuld that run for a 91 chevy lumina
Username: Ctmike
Ct.
Post Number: 3363
find one here:
http://stores.ebay.com/Iraggi-Alternator-and-Electronics
