Viewsat Ultra
Username: Zagros
Post Number: 168
Can anyone please explain how to manually put the keys for Viewsat Ultra.
Thanks
Username: Steph_raven
Les Cedres, Quebec Canada
Post Number: 48
Viewsat New Keys Step by Step Procedure
Use your remote and press the menu
click the option (5)
go to the autoroll and Turn autoroll OFF and exit by using the remote
Use ur remote and press the menu
press the installation enter the 0000 pin code
press the code, than press the nagra
than look for Dish 01 01 00 by using the remote right and left
than enter the keys as followed.
Make sure you inputed them in Dish 01 01 00 and NOT Dish 00 01 00
00 A3 63 F4 11 BC A3 B1 AC**do not touch this row**
08 - enter first 16 bytes of 0 key here
09 - enter second 16 bytes of 0 key here
88 - enter first 16 bytes of 1 key here
89 - enter second 16 bytes of 1 key here
if you are using dn for BEV:
than look for Dish 09 01 00 by using the remote right and left
Make sure you inputed them in Dish 09 01 00
ps i'm not 100% sure for DN i cut and paste from another site. should be good for bev
