Bronze Member Username: Lilpimpd
Post Number: 28 Registered: Jul-06
Posted on IS there really that big of a difference between these because i can get 04's for 150.00 cheaper?? And there 10"... |
Silver Member Username: Solobaric4life
Seminole,
Al
United states
Post Number: 183 Registered: Jan-07
Posted on i know that the l5 10's and 12's is the exact same loudness from the older to newer ones so im sure the l7's are the same way like black cones then silver ones same loudness, if same setup |
Silver Member Username: Ars88
P.I.M.P ,
Pakistani/In...
Post Number: 456 Registered: Nov-06
Posted on the old l7's tend to break fast...the cone the newer ones are more reliable but why l7? there is so much better out there |
Gold Member Username: Denali_on_22s
SSX,
Tenneki
US of A
Post Number: 1267 Registered: Feb-06
Posted on You mean to say the 04's arent blown? that's funny |
