Receiver Help
Username: Unreal_t
United States
Post Number: 34
I have a pair of Polk Audio Rti8 tower speakers. I have a Yamaha HTR-5740 receiver as well. Can anyone recommend me a receiver that will give me some more sparkle out of my rti8's? What would be a good brand of receivers to match up with the polks? Thanks
Username: Jethro
Lansing, Mi
Post Number: 141
maybe not a receiver you should be looking for to make the 4 ohm rti8's shine. maybe look towards a 2-channel power amplifier to supliment the current configuration using the yammy receivers pre/outs. This will take strain off of the yammy's power supply for HT and for 2channel music you will be sitting pretty obviously with the separate power amplification.
Username: Unreal_t
United States
Post Number: 35
What amplifier to you recommend?
Username: Unreal_t
United States
Post Number: 37
Does the amp add on to what the receiver puts out or does the amp just act by itself.
Username: Waa_i_xanuunaa
Lextington, Nebraska
hey guys am looking 4 pansat key data. ifu have plz let me now.or send me m_x_y@msn.com
Username: Project6
Post Number: 12218
Way to hijack a thread, afka!
You are in the wrong forum! Learn to read, you moron!
Tommy,
Sorry about that. The amp does not add to the receiver output. What is your budget? I would be very careful in choosing an amp for those speakers, an amp that can drive 4 ohm speakers is not cheap.
Username: Polksavage
Post Number: 99
rti8 speakers are 8 ohm speakers
Username: Johnny1
ii will buy b&w dm602 s3 speakers next week, can someone help me about recivers, which one you think is the better yamaha rx n600 or rx v659 or some other in that price, please answer. thanks
