i was looking at the BL and gots a few questions on them. im looking for a daily driver bump wit hifonics 1600watt rms or what u would say its puttin out 1100 watt rms. anyways wat would be some options to get for those subs.i was going to do the cooling but what about the flatwind or extreme lead.wat r they and should i worry about them
"If you are looking to use the sub for a daily purpose, I would think about the pole chamfer as the first option to do. It will relieve pressure under the dustcap and get things flowing better for minimal cost. After that, its somewhat of a tossup between the full cooling or flatwind. Both add thermal power handling... and to similar levels in some applications. If I were wanting to use 1500W+ Id probably get both. Anything under that and you can pretty much take your pick... Also, please reserve the BTL leadwire for predominantly SPL applications. The leadwire handles very higher power/current, but it also leads to noise in some applications as well as wear on the top spider if used for high excursion. Is this an issue for SPL or some louder daily drivers? Not at all... but if this isnt your application, dont get it. The standard stuff is as large as most use on their super uber SPL monsters... and they dont have issue :-) "
