Samsung DLP lound fan sound
Username: Richa321
Hello,
I have had my 42 inch HL-R4264 for about a year. Lately the background sound has started to be a bit loud. It is a high pitched wine that is becoming too loud! Is this normal? Do any of you have loud background fan sounds? When I mute it, it is clearly coming from the back of the machine.
Any thoughts?
Thanks
Username: Mrage
Post Number: 25
your color wheel
Username: Richa321
Thanks Sam. Any idea of cost?
Username: Mrage
Post Number: 26
go to samsungparts.com and type your model number in and it will give you a list of all parts just look for the color wheel assbly it should be around 200 bucks
Username: Richa321
Sorry to keep asking questions.
Are they easy to install yourself?
Username: Mrage
Post Number: 27
yea for the most part they are here is a site that might help you out with it http://www.jangro.com/a/category/samsung-dlp/
