Infinity Rewire
Username: Notoriousroc1
Post Number: 36
My main questions are:
Why is it necessary to do a rewire on a system with factory Infinity speakers?
Thanks in advance
Username: Gibson5469
Post Number: 130
im assuming it has a factory amp, and once you change the speakers you need to run new wires from the deck to the speaker location.
Username: Sinful_systems70
Post Number: 364
HUH!!! There is no need to change anything if the new speaker is rehooked to original wire and no other changes besides the speaker replacement has been made. The only time the rewire is needed is if you decide to change head unit and not use factory amp. Just trying to clear everything up.
